b16 obd2 into eg
b16 obd2 into eg
is it okay to swap a b16 obd2 from a 97 ek into a 95 dx hatch without converting to obd1? i have all the necessary things (i think), ecu, harness, axles, mounts, tranny, mani's, and etc. if i need anything else please let me know......
i guess my point is, i know it probably won't pass emmission but i know a guy the reason why i dont wanna convert to obd1 is i have all the parts that's obd2 and really dont wanna spend money trying to convert. so is it just a straight swap or is there anything else that need to be done??? pls help
would that mean i cant use some parts......ecu, dizzy, injectors...etc, since i'm converting to obd1? or would it be just the jumper that i would need and everything else should be just fine?
i have been searching and so far here's what i came up with.......................
correct me if i'm wrong pls i wanna double check b4 buying the engine.......b16 obd2 jdm...so far i know i can't use the harness because its rhd but i can use a 96+ integra harness to replace it and it plug straight to my jdm p2t. do i need to replace dizzy, injectors or whatever else pls pls pls help
