engine jark while driving
hi folks, i m new here. this forum is really cool. i have a 95 civic h/b eg4 with D15B2 engine. its a japanese import only 74k mile on clock. recently i m having some problem....
1. engine jark while driving. whole body jark for 1/2 min and then stop shaking again and smooth drive. i have my service done recently. even if i start the car and left it for a while its knocked off
2. while driveing ,,,, every time i accelerate its doesn't work for 1 min then its work (if u know what i mean) the car. and it DOESN'T STAY ON UNLESS I GIVE SOME GASS.(it doesn't happen normally, esp odd cold night )
there is no CEL or anything and CEL light working too.
i know i cant explain it properlly, if anybody know even what i should do??
WILL IT BE ANYTHING ABOUT CRANK SENSOR?
CAN ANYBODY TELL ME WHERE WOULD I FIND CRANK SENSOR IN 95LSI D15B2?
I HAVE KNOW IDEA ABOUT ENGINE SO PLZ SEND ME A PIC.
Modified by joy123 at 3:45 AM 12/16/2007
Modified by joy123 at 4:04 AM 12/16/2007
* B A N N E D *
Re: engine jark while driving (joy123)
Something keeps telling me it could be worn out engine mounts.. Not to sure but you situation sounds similar to mines. If im wrong someone else can give you better input.. But i think its your engine mounts torn or worn out..
Check Your mounts and maybe your iacv. My buddys em1 had the same problem and it ended up being the iacv. What also leads me to belive that its the iacv is that it only happends in the cold... just a thought..
Re: engine jark while driving (WhiteEkCivic)
i check the volt of the MAP sensor, its read 5 which is normal!!! i went to garage they chenge the headlight fuse 10 to 30. now it doesn't have any CEL. run perfectlly so far!!! dont know how long it will be ok!
calrodz
Honda Civic (2006 - 2015)
02-13-2016 07:29 PM
geoinvesting
Honda Civic (2001 - 2005)
12-24-2008 05:09 AM
Spade
08-02-2002 11:02 AM
