low voltage blinker problem
The front passenger side blinker on my '92 hatch stopped working late last week. I thought no big deal probably just a bulb so I checked it and sure enough the bulb had popped. I replaced the bulb and the blinker still doesn't work. Next I pulled the cover off my fusebox to see which fuse controlled this circuit and to my surprise found no listing for "blinker" on the fuse panel. I thought I must be going crazy so I searched this site and found this thread about the fuse layout. https://honda-tech.com/zerothread?id=1966666 Which pretty much told me what I already know, I AM GOING CRAZY.
I just checked voltage at the connector and it hovers around 2-5 volts with the blinker on.
The running light has 12 volts and the ground is fine. All other blinkers work just fine.
I am wanting to trace the power wire back to the fuse box but alas the issue I outlined above. Any help is appreciated.
zx2gotboost
08-25-2005 01:51 PM
