obd2 97 civic check engine light
ive looked by the ecu and see no jumper there but i know there is the service connector to check codes under the dash. i dont have a code reader so i want to jump the service connector the check the codes. anyone know which pins i need to jump it
Re: (boostedjdmdc2)
if you are talking about the 3 pin plug i dont think you can jump that...but the 2 pin plug you jump is attached to it about 3 inches up the wire
Re: obd2 97 civic check engine light (boostedjdmdc2)
you have to look a little more cuz its there it might be tucked up behind the ecu
https://honda-tech.com/zerothread/1901557
chippinpressure
Engine Management and Tuning
01-14-2010 05:47 PM
gsrhatch1126
07-05-2005 06:45 PM
vtecb20coupe
03-26-2005 08:23 AM
