Spun bearing ????
Old 10-05-2008, 06:09 PM
hondachris1994's Avatar
Default Spun bearing ????
If a block has a spun bearing, how would u tell? Im buying a GSR block and I wanna make sure ut doesnt have a spun bearing. Any help is appreciated.
Old 10-06-2008, 05:29 AM
anyone???
Old 10-06-2008, 06:10 AM
blkegcoupe's Avatar
Location: ....................................................................................................
you can tell by looking at the crank and rod bearings but you'd have to take apart the motor and i don't think that person would let you lol. but you also can hear it while running
Old 10-06-2008, 07:04 AM
SilverAWD's Avatar
It sounds like a loose bearing. Almost a knocking sound.
Old 10-06-2008, 08:11 AM
Default Re: (SilverAWD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SilverAWD &raquo;</TD></TR><TR><TD CLASS="quote">It sounds like a loose bearing. Almost a knocking sound.</TD></TR></TABLE>Im buying a block, i wanna know how I can tell before I put a head on the block and put it in the car. I know what a rod knock sounfds like, but i dont wanna pull my block and find out the new block has a spun bearing
Old 10-06-2008, 09:21 AM
King V's Avatar
Default Re: (hondachris1994)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondachris1994 &raquo;</TD></TR><TR><TD CLASS="quote">Im buying a block, i wanna know how I can tell before I put a head on the block and put it in the car.</TD></TR></TABLE>
Simple. Take the oil pan and girdle off the lower end and visually check the condition of the rotating assembly. You could even go as far as to take off a couple rod caps and check.
Old 10-06-2008, 09:39 AM
jdmkidd23's Avatar
Default Re: (King V)
yea pull the oil pan off! do a visual check!
eg:R
02-10-2007 10:47 AM
ntrider
03-03-2006 11:58 PM
brokenojoke
12-22-2005 09:25 AM
poch915
05-18-2005 01:31 AM
preludesi93-arg
01-01-2005 08:30 PM
Quick Reply: Spun bearing ????
