Z6 Only 3 cyl fireing.....
So my Z6 will only fire 3 cyl. wont fire the one on drivers side. ive replaced everything i could think of.... all but ecu and harness. compression is perfect and just put a new head on too... checked the voltage for the injector plug and its 11volts on and off. anyone have any idea what might be causing this problem? like i said ive tried everything i can think of and its not worked. any help would be great.
Re: (Stevens2266)
ok try swapping the bad injecter on to a different spot and see if the misfire changes over. if you have checked everything else then try a new injecter.
Re: (Stevens2266)
did you remove your ecu at all, I was having a problem with one of my injectors and it ended up being a pin was not getting a good connection at the ecu.
ive tried the switch. i have brand new ones in it now. ill try the ecu thing. so you just unplugg it and replugg it?
Modified by Stevens2266 at 4:03 AM 10/7/2008
replaced intake mani and fuel rail today and nothin has changed 4th cyl still wont fire. i switched the 4th adn 3rd injector wires and wtill no fire from the 4th cyl. anyone have an idea?
TwoKSiR
09-14-2010 03:25 PM
