ob2 1 wire o2 sensor
obd2 1 wire o2 sensor
have a 98 ex with a blown motor so just to get the car going again I am putting a obd1 d15b nonvtec motor I had. I have a obd2 to obd 1 conversion harness and will be running a p06 ecu so I will need to keep the one wire o2 sensor? After searching I found the white wire on the 4 wire o2 sensor harness is the signal wire would I just connect that to the 1 wire o2 or do I need to run a new wire all the way to the ecu? thanks
Modified by big22 at 11:40 PM 10/4/2008
Modified by big22 at 11:53 PM 10/4/2008
civicmatt
06-22-2003 07:27 PM
