no start after engine swap
97 civic ex 1.6 automatic. yanked the old motor. bought a 98 1.6. saw the numbers were slightly different on the fuel rail so i swapped the old one onto the new motor just to be sure. everything is hooked back up correctly and i had no left over harness connections. it will crank and crank all day and doesn't even try to start. i have gas in it, fuel to the rail, just seems like the injectors aren't firing for some reason. i sprayed starting fluid into the throttle body and it will start and barely run on that but it won't pull fuel at all it seems.
and wether this is related or not i don't know but when i turn the key to on or am starting it there is a wierd clicking noise coming from the glove box area. i thought it was a blend door but at the same time the d4 light is blinking real fast and the engine light is blinking real fast. both slow and then stop after about 10-12 seconds. both lights blink at the same rate as the clicking noise.
any suggestions as to what to look for?
Re: (allisonmo2)
well i am stumped. checked every connection anywhere i could find. everything seems fine, the distributor cap only goes on 1 way so i am not 180 degrees out. now what?????
Re: (allisonmo2)
Is the ground at the thermostat housing good?
Recheck all of your grounds..
One to the transmission.. the valve cover, Battery to chassis.. thermostat housing..
Modified by geebs at 12:37 AM 10/7/2008
multitracks
10-26-2005 03:08 PM
civicturbo22
01-25-2005 05:43 AM
stuntracer
13
12-11-2004 05:24 AM
