need help to get swap running.
ok so i have put a 94 gsr in my coupe. i go tot wire in vtec.. i hard wire from vtec solinoid and pressure switch right to ecu. but when i got to splice the wires in there arnt any there a4 and d6 have no wires going into them.. cool yeah its a non vtec harness my ? is where can i steal the 2 pins from to put um into a4 and d6
thanks ht..
and im running a blox mani so no 2nd butterflysd or knock sensor.
thanks ht..
318 Curves, 11 miles
Re: need help to get swap running. (luvmihatch)
When I had to add pins, I just cut a harness connector off of a junkyard car and de-pinned it, then reused the pins on the correct pinouts into my ECU harness. Make sure the pins are the same though - I found that OBD1 ecu pins will not go into an OBD2 harness plug... they're shaped differently. Probably vice-versa too.
90Rexx
03-26-2009 12:30 PM
projecthonda
02-23-2007 06:48 PM
