Installed ITR suspension and no i have no brakes?
after installing the entire suspension (00 civic hb) i bled the brakes about 6 times, starting furthest from the booster to the closest. then i tried to bleed the master cylinder alone and nothing from that. the brakes hold pressure til i start the car and then the pedal falls to the floor. i replaced my stock proportioning valve with one from an si and i cant think of any other reasons. did i miss something?
Re: Installed ITR suspension and no i have no brakes? (d!ckface)
Theres got to be a leak somewhere. or some kind of bubble leak. re-tighten everything. if nothing works it could be your master cylinder. when you pulled it from the brake booster was there fluid in the booster?
Re: Installed ITR suspension and no i have no brakes? (Fook_me_honda)
Never took the master cylinder off the booster. When I bleed the calipers I get a solid, steady flow with no air, I have leaks anywere. All the fittings are dry...
Re: (EG_fan_59)
ITR suspension so definately disc.
But remove the M/C and see if there is any leakage in there. Or try using an SI M/C. I believe they are different then the normal civic ones. just can't quite remember how......let me probe my head for a bit
400 HP Club
Re: (dividedas1)
when you undid the brakes did you dry out the MC? if so you need to bench bleed it and put it back in the car. If you had the calipers right off the car (witch I dont know if you did or not) but make sure the bleeder screws are pointing up.
Re: (B.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bob Dole! »</TD></TR><TR><TD CLASS="quote">You've got to change out your m/c too. ITR brakes are much bigger than the little ones that come with your hatch.</TD></TR></TABLE>
my buddy used his stock m/c in his 00 hatch and still uses it to this day, but he also blench bled his m/c before he bleed the brakes. its there a like to dexcribe how to do that?
400 HP Club
Re: (d!ckface)
you dont need to change the MC, if anything when swapping to rear disc you can change the prop valve. I think the 93 lx is the one with a 50/50 prop valve that will bolt directly into your MC and will give you equal brake distribution front to back.
you have a bad brake booster. if you have a solid pedal when the car if off and while holding the pedal start the car and the pedal drops to the floor, then u have a bad booster. sorry to bring the bad news
Re: (blkegcoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redline870 »</TD></TR><TR><TD CLASS="quote">you have a bad brake booster. if you have a solid pedal when the car if off and while holding the pedal start the car and the pedal drops to the floor, then u have a bad booster. sorry to bring the bad news </TD></TR></TABLE>
How, I drove the car to school an 1/2hr away then home and ripped my old suspenion off, put the new on and bled within 4-5 hrs. I'm thinkin the m/c is too small...
Re: (d!ckface)
possibly? im not sure. it just sounds like a bad brake booster to me. could be it just happened to go bad, just like when u walk into a room and flip the light switch and the bulb goes, nothing u did caused it, it just went bad. could be when the pedal went to the floor that u rolled a seal. sorry i cant help u out. once u find out what it is let me know cuz im curious to what is wrong.
first of all the correct bleeding procedure for you civic is RR RF LR LF. the lines are crossed because its a front wheel drive car. second stick with manual bleeding its 100 times faster and more efficient than pressure bleeding...(complete pointless.)
1sikhatch
12-07-2009 04:18 AM
yh23
05-27-2005 03:48 PM
MrIllegalX
08-24-2003 06:27 PM
