removing intake
Old 10-04-2008, 01:03 PM
y2kferari's Avatar
Default removing intake
My friend is taking his stock intake off his 93 ex civic coupe and putting cold air intake. He can unbolt the box, but the peice under the fender won't come out, and he can't see any other bolts but that peice won;t come out. help, thanx in advance
Old 10-04-2008, 01:17 PM
BlackoutVTi's Avatar
Default Re: removing intake (y2kferari)
Take off the front bumper, and look at the radiator support on the side, under the front of the fender. You'll see a bolt on a thick rubber bushing you need to undo before you can remove the snorkel. This will make it loosen up. If the snorkel simply rattles around in place while your putting pressure on it, it should be able to be worked out of there.
Old 10-04-2008, 01:35 PM
batallic's Avatar
Default Re: removing intake (BlackoutVTi)
ditto
Old 10-04-2008, 02:02 PM
y2kferari's Avatar
Default Re: removing intake (batallic)
well. When me and another friend took off my intake off my 94 civic, we never took off the bumper. Plus, I can't take off the bumper, so is there another way?
Old 10-04-2008, 02:11 PM
DOUBLExDEUCEx22's Avatar
i dont think you have to take off the bumper. take off the passenger side wheel. and see if you can take out the inside of the wheel well.. and you should be able to get at it. I have a 98 civic.. i know the make is different but this might work
Old 10-04-2008, 03:42 PM
batallic's Avatar
thats what did to remove the resonator, i was gettin my bumper changed so they remove it anyways, its pretty big to remove without taking off the bumper
Old 10-05-2008, 09:21 AM
You can't take off the bumper? Come on dude, it's a 93 Honda. Take it apart and figure it out. That's what Honda designed them for.
Old 10-12-2008, 02:23 PM
y2kferari's Avatar
I'm not taking off the bumper. its not happening. there is another way
Old 10-12-2008, 02:28 PM
EGferio's Avatar
Dude just take the bumper off it will make your life much easier.
Old 10-12-2008, 02:32 PM
So, did you get it?
Old 10-12-2008, 02:34 PM
y2kferari's Avatar
No. It was taken off my last car without taking a fender or bumper off, so there is another way.
Old 10-12-2008, 02:37 PM
DC2xFIEND's Avatar
hahaha
Old 10-12-2008, 02:39 PM
instrument's Avatar
just remove the wheel well splash guard and you can remove it.
Old 10-12-2008, 02:45 PM
y2kferari's Avatar
Default Re: (instrument)
thank you instrument. not exactly what I had in mind, but that is no problem
Old 10-12-2008, 03:20 PM
y2kferari's Avatar
Default Re: (y2kferari)
well. done. all I had to do was remove 3 bolts in the fender well(the front section) and bingo. easy access to the 3 bolts holding the intake in place. taking the bumper off would have been pretty much a waste of time.
Jeffaj20
08-07-2016 11:07 PM
ribal_gh
09-19-2012 07:16 AM
NONKonformyst
08-27-2002 04:12 PM
civicboy95
02-12-2002 10:28 PM
00fbp
10-23-2001 02:20 PM
Quick Reply: removing intake
