need some info going form a d16y8 to a d16z6
Old 10-03-2008, 02:22 PM
MrRabbit87's Avatar
Default need some info going form a d16y8 to a d16z6
ok so from what i've been able to search up i need to swap the dizzy from the y8 internals to the z6 because of the connector plug.
Then i am going to use my y8 manifold because it laying around and the major differences is that the location of the IAT is different.
Then i am going to use a jumper harness with a chipped p08 that got remapped as a p28.
So will the z6 plug up to my y8 harness with no problem? Or am i missing something?
And for the dizzy, is there anything specific i gotta look out for? I think the mounting points are different so i have to use the z6 body with the y8 internals... if not please let me know. Thanks
Old 10-03-2008, 05:23 PM
ImporTProphetZ's Avatar
I believe the harness plugs right in, and you have to wire up vtec. I am sure there are alot of write ups on this. try searching.
Old 10-03-2008, 05:50 PM
Nic
Nic's Avatar
Default Re: (ImporTProphetZ)
Use the y8 manifold the the dizzy everything else is plug and play.
Old 10-03-2008, 08:33 PM
MrRabbit87's Avatar
Default Re: (Nic)
i did search but the search is just to general. and alot of unrelated things pop up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nic &raquo;</TD></TR><TR><TD CLASS="quote">Use the y8 manifold the the dizzy everything else is plug and play. </TD></TR></TABLE>
So false info from the first guy about wiring vtec?? Do i have to swap the internals from my y8 to the z6 distributor or does the whole thing fit as a whole? after some searches i found some guy said the mounting for the dizzy are different so i will have to swap it.
as soon as i get the z6 i'll find out one way or another and i will update for future references.
MrRabbit87
50
04-02-2023 09:10 PM
TravisCadello
14
04-12-2009 10:37 AM
91integraLSVTEC
09-14-2007 01:02 PM
usmdspeed
07-27-2003 03:53 PM
Soulless
01-03-2003 12:15 AM
Quick Reply: need some info going form a d16y8 to a d16z6
