Help needed for h22a swap in a EG8
I got a 4 door 94 eg, and I just want to know what all do I need if I have the H22a. I got the H22a, with the prelude tranny it'self. The motor is obd1, I have the intake manifold with it ... no midshafts or axles though, just wondering all the stuff what I need ?
EG8 is a Civic 4dr, not a Del Sol.
You should do a search for info on this swap, it's been covered many times before. But here are a couple links from the FAQ page (you should always check that first, in addition to searching, before asking questions):
https://honda-tech.com/zerothread?id=650329
https://honda-tech.com/zerothread?id=434668 - Axle Info
As mentioned you need to research. However for a h22 swap you need to (quick run down): cut a square in the original shifter place for the cable shifter, get the hybrid axles, the mounts (when doing the mounts the factory passenger mount off the chassis and the new one is welded or bolted in. The alternator wiring must be extended on the h22 where is sits up front as opposed to the factory eg motor harness being in the rear. If using a usdm motor and ecu then you'll have to wire the egr system, is jdm then use a chipped p28 and your good (cause jdm dont have a egr system). Thats just a quick run down of it
Plateus
Honda Civic (2001 - 2005)
06-12-2006 10:40 AM
