two questions for you guys about axles and brakes.
Hey guys, 2 questions for you all, when you swap a GSR with USDM ITR tranny into a 93 DX hatch what axles get used? im getting all kinds of mixed answers every thing from I can use the stock dx axles to I have to use 2000 GSR axles. so whats the correct answer?
and the second question is the guy im buying the car from also did a rear brake swap on this 93 dx hatch and used 2000 civic si rear disk, he said he didnt touch the master cylinder or proportion valve, shouldnt the valve and or master cylinder be changed as well to maintain proper brake balance? he claims it stops perfect as is but i just figured i better check.
Seagull Management
Re: two questions for you guys about axles and brakes. (boosted91crx)
Re: two questions for you guys about axles and brakes. (94EG8)
thanks for the fast reply, so let me get this straight if he took the stock drum brakes off the rear and put disk on it and didnt touch the front then its fine?
Seagull Management
Modified by 94EG8 at 10:06 PM 11/7/2008
Modified by 94EG8 at 10:07 PM 11/7/2008
wow great info, is the 93 and 92 the same? you referenced the 92 si but this is a 93 dx. back to the axles, you listed versions i could use, are they normally the same part number at any store? and are any stronger or better to use then the other?
Seagull Management
Re: (boosted91crx)
