Need Help with codes please
So after getting my b16 in the car and starting it I got a swamp of codes.
code 3: Map
code 6 Water Temp Sensor
code 7: TPS
code10: Intake Air Temp
Everything is pluged in and it all worked fine before replacing the bottom end. Now all of a sudden I get all these code. I replaced the Water temp sensor in the thermostat houseing and nothing happened, And the gauge still doesnt work. When I unplugged the MAP the Car still ran, Same when I unplugged the TPS (With car running)
Ideas please?
code 3: Map
code 7: TPS
Ideas please?
Re: Need Help with codes please (Mill-Town)
reset the ecu ....
undo the neg cable turn the key on like you are going to start it and hold it for 10 secs reconnect the battery, start the car .. see if they come back.
Re: Need Help with codes please (mikehawk)
Originally Posted by mikehawk
reset the ecu ....
Re: Need Help with codes please (CTR_B)
Originally Posted by CTR_B
Re: Need Help with codes please (Preferio)
Originally Posted by Preferio
Do I know you from GDD? The place 'I have been bannished from... The horror...the horror...
No resetting it didnt do the trick. As far as I know all the connectors are in the right places.
Originally Posted by Mill-Town
Lol I don't see how all those things go bad at once?
Re: Need Help with codes please (mortificationrock)
Which one controls the temp gauge?.. I tried switching them but I will do it again just to double check
