Stuck Rotors.
Stuck Rotors.
So my brakes have been vibrating lately so I finally decided to go get my rotors turned everything else was cake, but when I got to the rotor I couldn't get it out....it's stuck to the hub. keep in mind I replaced the brakes not too long ago (maybe 9 months) Anyone have the same experience and know a trick that will get them out WITHOUT damaging the rotors? Your responses are appreciated.
Re: Stuck Rotors. (zero708970)
if you look at the rotor, you will see that there are at least 4 extra holes, besides the 4 or 5 used by the lugs.
2 of the screws are for the rotor hold screws that keep the rotor centered and on the hub. assuming you have removed these two...
there are 2 other holes on the rotor that are threaded. the purpose of these was exactly for your situation - to get off stuck rotors with ease.
i dont know the exact screw thread/pitch size (sorry), but you're supposed to turn the screw into these holes, and it pushes against the hub, forcing the rotor to come off.
go to your local honda dealer and ask for the screw. my dealer didnt even charge me for it.
good luck.
good luck.
Re: Stuck Rotors. (da1lydr1ver)
good luck.
good luck.
Re: Stuck Rotors. (Honda-Pilot)
Actually they are warped I took them off for that exact reason....they're being turned as we speak...or type. Whatever. Anywho thanks for the help I bought these two bolts for .93 cents and the came off right away. I always wondered what those two extra holes on the rotor were for.....
pcorad
09-17-2001 05:09 PM
