help fast! axle wont come out of trans
ok so the axle will not come out of the trans... i dont know why any suggestions?
d-series del sol..
d-series del sol..
Re: (z6hatchboy)
good point if your pulling it out @ an angle it won't come out. They have a locking clip on the stem of the inner spindle to prevent them from coming out.
Good luck and try what was mentioned above.
Re: (Garage 808 Hatch)
Originally Posted by Garage 808 Hatch
if thats doesnt work, you may need to pull the other axle and drive it out from the other side
take a hammer and hit the cup it self and then pop it out with the pry bar. it may take a couple of hits on the cup but not to hard ok.
yes this does work i have gotten may mdx and tl's with the same problem and a good whack on the axle and then it will pop out.
Re: help fast! axle wont come out of trans (longshot)
d-series del sol..
d-series del sol..
use 2 thicker flathead screwdrivers on opposite sides of the axel, i just went through this BS a few days ago, i find if u apply equal pressure on both sides of the axel it comes out that much easier!!!
project91crxsi
08-21-2009 05:56 PM
