Integra 5 Speed Swap into EG Body
Ok. I did the search, I can't find anything. I got a del slow automatic and got my hands on a free LS. I was wondering if the manual swap was complete bolt on over to the other side as in the petal assembly, throttle cable, clutch cable, slave lines, etc. Anyone with any insight that can shed some light would be great. Thanks.
Re: Integra 5 Speed Swap into EG Body (94EG8)
I plan to use everything including the motor tranny and ecu. Im sure ill have to modify the linkage to make it fit right though. I am just making sure the petal assembly will bolt up and I wont have any issues. The rest should be cake work. Do you know if the assembly works?
Seagull Management
Re: Integra 5 Speed Swap into EG Body (marty)
Originally Posted by 94EG8
Pedal assembly is exactly the same as an EG setup. And you will either have to modify the shift linkage or buy one for a Del Sol Vtec.
Seagull Management
If your 100% sure im going to start ripping apart two cars.
LittleBigWelsh
05-19-2013 01:33 AM
j4s0n1337
12-29-2010 04:35 PM
