How to do a resistor box on a 94 Civic coupe
I'm at the point where you test for conductivity on the dead end connector but I'm unsure about it. What setting do you use on the multimeter to test for conductivity? When I set it on VDC, I got 6/8 readings that had some results. The other two gave me nothing. I prolly have it set on the wrong setting. Thanks
Re: How to do a resistor box on a 94 Civic coupe (gnozahs)
look on the meter and swith it to the symbol that looks like sound waves. when u touch the two probes together the meter will beep
I switched the setting to where the two probes would beep when touched together and when I went to the dead end connector, I got 2 that had some activity. The other 6 had no readings. I am confused. Any ideas on why this is occurring?
Re: (gnozahs)
im not really sure on how to connect a resistor box but click the red search button and type in resistor box and you will figure out exactly wut u hav to do. you hav low impedance injectors right??
Vtec92Civic
07-12-2003 09:09 PM
