help engine codes
Old Nov 8, 2008 | 12:19 PM
monkey_boi's Avatar
Default help engine codes
ok so here is my problem
i have a 92 eg cx model that had vtec with the ecu harness
and the engine harness has no vtec
the previous owners did this kind of harness because they had a b20 turbo and did not need the vtec.
ok so as a result i have a chipped p06 ecu chipped to a stock p28
and the 2 harnesses vtec and non vtec
and i get the engine codes 21 which means that the vtec is not connected
so when connecting the vtec i get code 22 which is the vtec oil pressure switch
but i know that i have to connect that and vtec will pop
but by any chance would that cause the car not to rev over 3500 rpm ????
Old Nov 8, 2008 | 10:41 PM
monkey_boi's Avatar
Default Re: help engine codes (monkey_boi)
does anyone know anything here mang someone help
Old Nov 8, 2008 | 11:30 PM
jdmjohnyyy's Avatar
you should be able to go past 3500rpms, unless your runing in limp mode
eaust96
Honda Civic (2001 - 2005)
Feb 4, 2014 05:59 PM
villaluz14
Feb 1, 2012 08:04 AM
freakaccident
Jul 27, 2010 03:02 PM
JDM-MONKEY
Jan 14, 2006 10:10 AM
