FENDER BENDER!!!!!!!! need help....
.....so the gist of it is about 2 hour ago my friend calls me up to go outside, he was gonna help me with my alternater belt sqeaking problem i was having so i go out side (by this time it was already dark) and i go to open my drivers side door and i hear a huge snap, so i close my door and sure enough my fender was completely smashed in!!! i was Fu<ken pissed espesically since i had jus got new fenders from PASSWORD:JDM a few weeks bak.... ok so my question is, i still have my stock fender frm before but i dnt have anything to cut into it with(to install my side marker).... so wht would i need to cut into the fender to make it look decent?????
(will post pix tmrw)
Re: (z6hatchboy)
i agree with z6hatch. its easy, get a dremel and some templates from honda-tech and just cut accordingly. I've done 2 sets of civic fenders and 1 set of integras.
good luck
good luck
Re: (doubleoazn03)
make sure you dont cut the holes too big tho. make a template from your pw:jdm fenders out of cardboard and cut the other hole to match exactly. thats what i would do...
Click here if you have 96-00 civic https://honda-tech.com/zerothread?id=1928843 and here http://members.***.net/ninety2...r.htm if you have 92-95. it will explain everything you need to know
Re: (mattyv)
OP: like i said...get a piece of cardboard and measure from the good side (from the door to light, bottom of fender to light, top of fender to light, and from the headlight to light.) make sure they are the same and make sure your light lines up straight and take your time. i didnt take my time and messed up a fender. there really isnt a certain place to put them...but it would look funky if you had one in one spot and the other in a different spot.
