Car goes into gear but dosent move?
Well we swapped in a perfectly good y8, car we removed it from ran good. We Didn't change anything except for fluids. Well we bleed the clutch and my bro goes for a test drive. pulls out of the driveway and goes down the hill, then stops and I hear him revving. He gets out and tells me the car wont move but it goes into gear, so I have no Idea what it could be.
Location: ....................................................................................................
does it grind? need to tell more, does it shift into any gear smoothly? can it go in reverse or any other gear? any noises? ^^like above could be axles, you won't know anything untill you look at it i mean honda tech can't be at your house in 5 mins.
Re: (blkegcoupe)
It dosent grind, it was perfectly fine before we pulled it out of the other car. It shifts smoothly, no noises and it dosent move in any gear. I will check the axles.
an axle poping out isnt gonna be quiet. you'll hear it dragging the ground or see it under the car if you got out and looked. he hasnt mentioned noises yet
Seagull Management
Re: (SOHC_4dr)
Originally Posted by SOHC_4dr
i have never seen a honda axle just drop out. you would really hear something if it did. how does the clutch pedal feel? is it any diff?
Re: (z6hatchboy)
Originally Posted by z6hatchboy
If it indeed is in gear, the axles are not in place or its a problem in the tranny, thats the only two things it could be. Check the axles though, they could've slipped out
BolivianFuego
06-04-2006 06:12 AM
vtec69
14
03-29-2003 12:20 AM
