'00 Civic Springs fit '92 Civic Coupe?
A friend of mine is wanting to put some '00 Civic springs on his '92 Civic and just wanted to ask if those would fit. I have had 92-95 Civics for years, but never had this situation come up. Thank you in advance for any help.
Cool Cool Island Breezes. BOY-EE
yes. They will fit. Notice how lowering spring manufacturers make springs for "
92-00" civics? The springs are of the same dimension.
Shock manufacturers also make shocks for "92-00" civics.
That alone should tell you that the springs are the same.
I've put 99 civic springs on a 92 with 92 shocks. They fit just the same. Yes, they will work. For sure.
Former Moderator
It's worth noting that the shocks themselves are not identical. Fronts are 1005 interchangable, but 92-95 have brake hose brackets, while 96-00 do not. Rear shocks on the 92-95 have a wider lower fork on them, so when using 92-95 shocks on a 96-00 you need to add washers, and whn using 96-00 shocks on a 92-95 you must remove material from the lower control arm bushings/sleeves to get them to work.
Other than those two differences they are interchangable.
Former Moderator
BTW I don't think anyone has pointed this out yet:
There is no such thing as a 1992 Civic coupe
The coupe was first introduced in the 1993 model year.
96-00 springs will fit 92-95, but for shocks the fronts are interchangeable but rears are different but will fit with a little cutting of the bushing
spoon23_JDizM AkA SpOoN20
11-16-2005 04:16 PM
njandrewg
10-03-2005 02:39 PM
eastbay92cx
11-23-2003 08:53 AM
