New EM1 OEM Lip fitment
hey guys i just recently got me a new OEM lip for my em1 but there are gaps in the corners from the lip to the bumper. why is that? is there a certain order i need to go with? start inside and work inside? i started outside and worked inside. the lip and the bumper are both OEM honda.
thanks guys!
thanks guys!
Taken from the Honda IN.
If you installed it like this then there should be no problems.
1.Using a pushpin, pierce the front bumper at the
centers of the four dimples on the right and left ends
of the front bumper as shown. Slide a spring nut over
each hole you just made.
2. Slide a clip nut onto the front bumper through each
of the nine cutouts in the front bumper. Slide the
spring nuts onto the front bumper.
3. Position the under spoiler on the front bumper, and
install the nine shoulder bolts and four self-tapping
screws.
To The Dealer Service Technician:
Please copy this page and give the copy to your customer.
• Be sure to remove the front under spoiler from the front bumper when a hook is used to tow the car.
1. Remove the nine shoulder bolts and four self-tapping screws to remove the front under spoiler from the front
bumper.
2. Reinstall the front under spoiler in the reverse order of removal after using a hook.
screws.
bumper.
k i will try this and see what happens.
i will let yall if it works or not.
thanks guys!
