p28 on d16z6
p28 on d16z6
I got a p28 comp in my 93 coupe and the other day it was having trouble trying to start but after it started it keep back firing and wasn't idling right. so when I was driving it and I was red lining like 5600.
new ecu right? cause I might get a p72 ; will that one give me any problems?
if you get a new ecu, get a p28. a p72 will make you run rich and will throw a knock sensor code. its something else, go to a mechanic. maybe your dizzy is fudged up, or you jumped a tooth.
I wouldnt say that ecu was bad. is there a solid light? even when you jump the service connector?
the computers limp mode is 3k not 5600.
If you decide you want a chipped computer, lmk, I offer the best prices.
idk im new to the honda game but it might be the dizzy idk cause I started it and I was pressing the gas and it wasn't reving or nothing it just keep sputtering then it starts bouncing off idle so ima take it to my boy and see whats wrong?
iight and i got another issue lol like the throttle body cable under my gas pedal is loose for some reason so like when i press the gas it has like a lag to it after i reach a certain point it pulls the cable and then it revs. how do i make that tighter?
But first, take the intake off and look in the throttle body and have someone push the gas pedal slowly and gradually (engine off) and have them tell you exactly when they push it. If the butterfly starts to open as soon as then press the pedal, it's not out of adjustment and your problem lies elsewhere.
JDMb18c1HATCH
08-20-2010 07:06 AM
