location of the 2nd o2 sensor outlet?
i had a recent y7 to y8 motor swap in my ek with 00 ex wire harness. i had a local shop known for honda motor swaps to hook the wire harness up for me and when they were done they said the secondary o2 outlet was missing and all i needed to do was get a p28 ecu and jumper harness and convert to obd1. i wanna keep obd2 and just want to add the second o2 back on. i need help on which part of the wire harness the secondary o2 snesor goes i have another cut outlet and o2 sensor ready to go.
The second O2 comes off the Car harness in the EX/SI and off of the engine harness in the rest of the civics. Just depends on which engine harness and header you are using.
If your using the Stock harness w/the stock header which is what it sounds like you are using, then you have to add a second O2 bung and a Jpipe and run the wires to the factory Secondary plug.
If your using the Y8 engine harness your still going to need a Jpipe but just run the wires to the ECU.
hondahookup.com hasthe service manual you can get it on page 2187 has the 2nd os
http://www.hondahookup.com/manuals/
HatchSpeeD
05-23-2008 05:17 PM
exare250
11-24-2004 10:59 AM
mjrage
23
08-16-2004 10:12 AM
