remove 2 layers and keep 1 in the head gasket ??
Old 11-29-2008, 12:14 PM
black-vtec's Avatar
Default remove 2 layers and keep 1 in the head gasket ??
hey,
i saw the stock head gasket for the h22a and it was consist of 3 layers..
what if i remove two of the them and keep the middle one to get high c.r
will that work or not ??
what do u think guys
Old 11-29-2008, 01:25 PM
Master Detailer
98civdx's Avatar
the thinner the head gasket higher comp. thicker= lower.
i dont understand why you dont just buy a thin head gasket,
im not a pro but if you do that do a stock gasket you may over heat it.
Old 11-29-2008, 02:58 PM
black-vtec's Avatar
so, where can i get thin head gasket.
Old 11-30-2008, 05:15 AM
black-vtec's Avatar
any one ?
Old 11-30-2008, 06:25 AM
Brian Hinson's Avatar
Cometic may be able to help you out, but it seems to me that the difference in compression would be so minimal its not worth the risk of overheating.
Old 11-30-2008, 08:06 AM
Frickr's Avatar
friend of mine did that do his d16y8 and there was a tone change in the exhaust and felt a little quicker. then the car started overheating, warped the head, and messed up a bunch of other things on it.
Old 11-30-2008, 11:21 AM
The Lobster's Avatar
dont take layers out of your head gasket...
which was ^ why your friend car got messed up. it wasnt cooling right.
just go to www.cometic.com i have ordered from them before they do good work.
just keeping the middle layer wont seal the block to the head...
Old 11-30-2008, 01:53 PM
Master Detailer
98civdx's Avatar
cometic is good but just as he said
your not gonna get much for power, i would just keep the stock size, and look for other ways to get more power.
Cho0se
02-24-2020 02:59 PM
da_33
01-11-2007 11:12 AM
Quick Reply: remove 2 layers and keep 1 in the head gasket ??
