TPS question
well i probed the mid wire (red/blue) and i got 1.8 closed and then a woping 8.0 wot? but i dont have a code tho..but if i unplug the connector then it will
your voltage readings should be .5 to 4.5 volts. It has been awhile since i tested a tps on the d series but your readings definitely don't look right. If you unplug any sensor, you'll get a code. Why are you suspecting the tps?
streetsold6teeny8
03-24-2012 06:46 PM
