Fuel pump question
Old 12-02-2008, 01:59 PM
Jimster480's Avatar
Default Fuel pump question
I just finished building my new engine and im planning on boosting it (16 PSI .50ar). I'm gonna run 450cc injectors, do I need to upgrade from the stock fuel pump because people are telling me different things.
Old 12-02-2008, 02:05 PM
Man U FTW
Schister66's Avatar
Well your "goals" if i can call them that are rather vague. PSI is not a determining factor when deciding on which parts you'll need. This isn't Gran Tourismo.
What are your power goals? You will more than likely need to upgrade to a Walbro 255 and possibly get a larger set of injectors. The stock fuel pump shouldn't really ever be used on a turbo setup unless you're shooting for something ~200whp or less. For the $100 it costs to buy a Walbro, its best not to chance it...
Old 12-02-2008, 02:15 PM
Jimster480's Avatar
well i just finished building a D16Y8 for boost. I dont really have an HP goal but my friends are telling me that with a good tune i should be putting down ~300WHP with my build.
and larger than 450cc or u meant larger than stock?
Old 12-02-2008, 02:21 PM
jfruauff's Avatar
yes 450cc should be enough for your setup and get the walboro 255 pump its 100% needed for any extra power. For the 100 bucks its well worth it. Fuel is the last thing you wanna run out of.
Old 12-02-2008, 04:40 PM
Jimster480's Avatar
ya very true.
Old 12-02-2008, 04:59 PM
drtysohc's Avatar
Walbro 255's are so cheap and easy to put in there really isn't a reason NOT to put one in.
Old 12-03-2008, 04:26 AM
Jimster480's Avatar
thanks alot everyone. I'm ordering one today.
Old 12-03-2008, 08:57 AM
Man U FTW
Schister66's Avatar
If you're looking to make 300whp, you may as well upgrade to a larger set of injectors now and save yourself the money and hassle in the future. If you were to nearly max the injectors at say, 300whp and later decide that you want more (since the block can handle it), you would have to change injectors and completely retune the entire thing; whereas, if you had large enough injectors the first time, you'd only have to up the boost and change a small portion of the tune. The same holds true for your MAP sensor. Get a 3bar the first time...those are the two things i did wrong on my first setup that cost me more in the long run.
Old 12-03-2008, 03:29 PM
Jimster480's Avatar
yea but 450CC will be fine for that. I dont have any plans on running more PSI. Its a vitara/scat/acl build. The pistons are only supposed to handle up to 20PSI. ALthough people do more than that I will be fine @ 16 PSI. its my DD, ill build another engine for a real race car in a couple of years lol.
Old 12-03-2008, 04:40 PM
Man U FTW
Schister66's Avatar
PSI doesn't mean anything as far as power capability. That setup you have is good for ~400whp if not more depending on the fuel.
Old 12-03-2008, 09:07 PM
Jimster480's Avatar
yea true, there is a 400HP Vitara club. But either way im not gonna push it that hard. Its my DD so ya.
umair
11-29-2007 11:49 AM
deucedeuceEK
06-02-2007 04:33 AM
matmann
09-17-2006 03:57 PM
tinkfist
04-24-2003 03:43 PM
1tyme
10-22-2002 12:36 PM
Quick Reply: Fuel pump question
