6th honda civic gsr swap
Okay, I swapped a Obd1 Gsr in a Honda Civic 1998 EX. i did all the wiring. Am using a obd1 alternator and obd1 distu from my gsr. I also did the Crank sensor bypass. Here the problem the car will barley try to start i have to crank it a few times, when it does start it will idle a bit and then it will die when i push on the gas pedal. what cause this? Also am still running the obd2 ECU that came with the civic. Even using that Ecu wouldnt it still Idle?
Re: 6th honda civic gsr swap
Check Fuel Pump, and plug the obd1 ecu in and get codes. or do what i did and convert the obd1 b18c to obd2. and use the p72 ecu. also what ecu are you using? stick or auto?
3rdgencrx
12
02-14-2007 05:26 PM
