D16z6 swap in to a 96 civic ex. HOW HARD?
Just need to no what type of thing will come up on the swap? i heard the dizzy wont bolt right up and that one or more sensors will have to be tricked. any on with info please let me no
P.S. I am Staying OBD2
well its illeagle to put a motor in thats a lower odb then what your car is now. EX: putting in a odb1 motor in a odb2 car. but it shouldnt be hard all u need to do is use a jumper harness i believe. depends on where you live. In NJ cops arent to bad with that stuff, but Cali on the other hand.. i wouldnt do it from what iv read
Seagull Management
i need to know this too! i already have a d16z6 block/ head/ intake mani./ header in my garage, next to my ek with a blown stock motor (obd2)! so pretty much i have to do this swap! i know i need a vtec ecu n harness n dizzy, but which ones should i use? would 99 ex vtec work? what else would i need?
I have the jumper already just not the p28. my girl has a chipped one in her 95 Ex and when i tryed to test out the jumper with her ecu i blew the y8, (spun bearing) i think. My y8 didn't like the 8000rpm to much
im not worried about passing smog or anything right now, i just need my hatch going its my only car! but will i be able to use my stock distributer or do i need to change anything else?
the p08 head has a different bolt pattern for the dist, all the sohc dists bolt up except the z6/obd1 d15b. you dont need to use the y8 head, just the y8 intake manifold. the the z6 block doesnt have a crank angle sensor
If he wants to use a p28 then he'll be fine. but if he wants to use the z6 head and the obd2 ecu i dont know what obd2 diz would bolt up to the z6. sounds like none will. not to mention the p2p ecu looks for the ckf. which you either have to swap the y8 oil pump assembly over to the z6, or do the ckf bypass.
ok go to http://www.streetlightz.com/OBD2B-to...mper-P128.aspx they have a few for sale for 65 bucks. good deal. hope this helps!!!!!
Re: D16z6 swap in to a 96 civic ex. HOW HARD?
i put a d16z6 in my 96 everything hooks up but 2 plugs can anybody tell me is that how it pose 2 be i did everything y8 intake on z6 block and use the obd2 harness just waitn on the dizzy harness for obd 1 dizzy 2 obd2 harness.and yes i will run a p28 and have a jumper harness
dtrujillo92
09-20-2018 08:21 AM
krysted9354
06-02-2011 08:45 PM
beninitEk96
12-03-2008 04:01 AM
