will a 99-00 tail light fit on my 97 dx coupe?
H-T White Ops
Turn signal bulbs (and outer wire harnesses) are different though. In order to be legal, the '99-'00 lights will need amber turn signals.
It helps if you use the harness from the '99-'00.
nah you dont need the harness. Just go get your bulbs in amber color. Thats what I did for my lights.
H-T White Ops
The ideal way to do it, if you want the other taillights, is to swap in the correct harness too.
I do things the right way. I do not like short cuts and there really is no reason to shortcut on this. It's a common harness.
I didn't say you needed the harness. It's helpful though. Those lights are easier to find than an amber 7440. Those are usually special order bulbs. Finding other bulbs to fit can work, but is not ideal.
H-T White Ops
http://advanceauto.know-where.com/advance-auto-parts/
The harnesses often come with the taillights, which I assume most would be smart enough to buy used anyway. The cost difference between lights that do and do not come with harnesses is very low, if there at all.
I'm not talking about a body harness. I'm talking about the tiny harnesses that you plug the bulbs into. They're not even that expensive new from Honda.
blinger
02-27-2008 08:48 PM
Mikes2000civicsi
Northeast (Sales)
06-30-2007 10:51 PM
BLCK97EKCOUPE
04-13-2007 08:45 AM
