Tapping sound from intake, #1 area?
Not exactly sure but it sounds like around the intake, number 1 cylinder. Its a 1998 Honda civic EX w 81K miles on it. Its been making the tapping sound for a while. I adjusted the valves as per specs last weekend, and the overall engine is quieter, but I still have this tapping noise in the morning, and even some times during the day when its up to normal op temp. It almost sounds like when you take a PCV valve and rattle it back and forth. It seems to do it on engine acceleration, up to a point, and then back down on deceleration - probably in the 1-2K rpm level.
It does not sound like a knocking noise - I've had massive rod knock on another vehicle, so I am familiar with the sound. This is almost a metallic tapping noise...
Any help appreciated. I wonder if I should seafoam the engine and clean any crap out that might be in the galleys, etc?
Thoughts on what this might be? Thanks again!
Resident Gearhead
Re: Tapping sound from intake, #1 area?
Basically keeps the VTEC rocker arms from smacking around when not engaged.
Very common problem, especially older DOHC VTEC engines. SOHC do have them
(4 vs 8), but I haven't heard too much about them being problematic.
Just a guess really.
Thanks! Can anyone suggest how I can narrow this down? I hate to throw $$$ at something blind... thanks again!
Also, I normally run synthetic oil, but it looks like the place that changed my oil this time used regular oil. I was wondering if seafoam to clean the crap (if any exists - I'm faithful on maintenance) would clean things out, or if seafoam is not a good idea? I assume that you run it for a couple of days before changing the oil out? Any input would be appreciated. Thanks again!
Seafoam is good but I dont think it will fix your problem. It is good for cleaning the engine but your only supposed to run it for a few minutes max. It thins the oil and that would create more problems. Im having the same issue. I tried some lucas oil stabilizer because of its thickness but still no change. Im gonna attempt a valve adjusment soon.
