97 civic with b16a what usdm clutch
ok i got a 97ex with a b16a swap in it . just boght it and the swap was already done. dont know alot about the car but it needs new cluth it has a hydro tranny so what year model usdm cluth can i get for it. the car has alot done to it for how much i got it for but thats not what i am worried about the big stuff is out of the way, now i just need to tune it . come to find out the ecu is chipped but the vtec still does not kick in but that is a hole nother post. please help my caqr is down and i am on foot . what should have been a three hour job is now goig to take i little ;longer till i find the right cluth
Re: 97 civic with b16a what usdm clutch
Any B series clutch will work. Depending on the kind of numbers you're planning on putting down will determine how aggresive of a clutch you will need. Vtec probably doe't work because whoever did the swap was probably just too lozy to wire up vtec to a non vtc model civic. What model civic do you have?
my bad i called in the vin numbers in to the dealership and they say this car came with the d16 sohc vtec motor stock usdm ex. now it has a b16a in it and a hack job of a harness. the ecu is chipped and it has a jumper down to obd1 but at some point someone still jumped the jumper for some odd reson. but anyway the car still runs and drives but down right now due to buying the wrong cluth. i kmow the 99-00 usdm si came with the b16a2 so is that the clutch i should look for . i did get a stage three xtr but they sent one for a d motot by mistake so now i have to get them to fix it but till then on foot . sucks but its a new car to me and have to find out things as i go ya know. then one day i will know all about it and can buy thre right parts for it.
lechuza05
03-20-2006 11:52 AM
mojoGSR92
02-01-2002 12:00 PM
