Honda parts # question look picture!
Well im putting a b16 in my 00 ex and i have all the mounts from a 2000 si but i need the driver side engine bracket with the two bolts coming out of it. I have the picture and info from majestic honda but i cant figure out which one it is. Its the one that says E-14-1 in the bottom right hand corner of the picture but which one should i buy? Sounds really stupid but what the hell. VVVVVVVVVV
http://www.hondaautomotiveparts.com/...28DOHC+VTEC%29
Re: Honda parts # question look picture!
11910-P30-000 BRACKET, ENGINE MOUNTING $51.58
You need that one. Yes, you need that B series mount for the swap to fit correctly. The two studs that sit up vertically are sold separately from that part # as:
90041-P01-000 BOLT, STUD (12X40) $5.33
You need two of the studs. Unless you want to re-use your old ones (if you can even get them out).
Crazy Honda Guy
That's the correct part....you are looking at the wrong diagram for the proper listing on it though....it's under engine block
Part number is- 11910-P30-000
http://www.hondapartsdeals.com/hpa_p...php?vin=&Label[ProductID]=CIVIC&Label[YearID]=2000&Label[DoorID]=2&Label[GradeID]=SI&Label[AreaID]=KA&Label[TransmissionID]=5MT&Label[SectionID]=ENGINE&Label[IllustrationGroupID]=CYLINDER+BLOCK+-+OIL+PAN+(DOHC)&ProductID=4&YearID=18&DoorID=1&Gra deID=11&AreaID=2&TransmissionID=3&SectionID=1&Illu strationGroupID=1739
Derek88
11-17-2009 04:45 PM
tyler100
11-02-2009 02:25 PM
stackz
01-16-2007 01:18 PM
