1993 Del Sol - Check Engine Light (code 20) - I need your expertise!!!!!
I have 1993 Del Sol (Civic) and the check engine light recently came on. I disconnected the battery to see if it is just a temporary thing, but the light stayed on. Here are my questions:
1) Where can I go to check the CEL code? I went to a nearby Autozone yesterday, but they can only check cars that are 97 or newer.
2) I need to take an emission test soon and they won't check with the light on. How can I turn this off until I get the problem fixed? If you know a way, please be specific as I'm not an expert on car fuses, wires, and where they are located...
Thanks!!
Thanks!!
Re: 1993 Del Sol - Check Engine Light - I need your expertise!!!!!
you cant just turn the light off, you need to fix the problem of the CEL will continue to come on. pull the code as described in the CEL sticky and go from there. all you need is a paperclip to get started
H-T White Ops
FYI, Autozone can check OBDII cars, which are 1996 and newer (and some '94s and some '95s - I've only managed to see one of these that was OBDII so far).
But yes, check the code using the paperclip trick, figure out what the code is and then post back!
It's just that I have to get an emission test done for the sticker on the license plate and I don't know if they will test the car with the light on. I want to turn the light off temporary, pass the test, then fix the problem when I have more time. I have to get the test done within next 10 days and I don't have time to fix the problem. Any trick that you are aware of?
You don't know whether you have a simple or complex problem until you pull the code. When done, post them and then reset the ECU to see whether the same code(s) repeats.
BTW, you can reset the ECU (clear the codes) by removing the hood Back Up fuse for about 3 minutes.
H-T White Ops
Depending on the test being done and the reason for the CEL, even if the light itself is not on you might not pass the test.
You REALLY need to pull the code. It takes about five minutes.
On the passenger side of the glove box there should be a 2 pin connector (it's often next to a 3 pin connector, but I can't say that's true for every Honda). So find this 2 pin connector.
Take a paperclip and bend it into a loose U shape. Stick the paperclip into the 2 pin connector (one end in each hole on the connector).
Turn the ignition key to ACC (car on, but engine not running).
Your CEL will begin to flash. Count the flashes. There will be long (quick) and short (slow) flashes. Count each and write them down. Watch it a few times to make sure you're getting the same codes. You could have more than one code stored.
Now that you have those codes, look online for the meaning. Autozone also has a Computer Codes book that should be for sale with the rest of their books (it's blue). This book lists the codes and how to pull them as well.
Once you have the code(s) you can fix the problem. It could be something very easy.
Sol to Sol
lol Just do it, and let us know, THEN we can tell you how to get past your test.
Ron and NOFX are two of the best helpers here, but they cant help, if you don't help them
Originally Posted by jena_blondie
I am going to fix whatever the problem is since this is my little baby, but I was wondering if I can turn it off so that I can pass the test then fix it when I have more time.
Depending on what state she is in the car can pass. Jump the service connector, pull the code and get back to us. Mostly all CEL codes are fixable within a few days.
Check Engine Light (CEL) 2 Long Flashes....
....CEL came on for my 1993 Del Sol Si.....
I did the paper clip trick on ECU and received 2 long flashes.....I waited to see if any other codes are coming up but received only 2 long flashes repeatedly.
Is this mean the code is "20 - Electrical Load Detector" ??
I am not sure what that is and how to fix it...Please help!!!
Re: Check Engine Light (CEL) 2 Long Flashes....
I just googled it and it says that code is for the communication between the alternator and the ecu. It tells the IACV to idle more or less..and its saying its in your engine bay fuse box, it should be the brown fuse it looks like a box in there... Hope this helps...
WOW~~ YOU GUYS ARE GREAT!!! THIS IS GOING HELP MY DAD FIXING THE CAR...I HOPE HE KNOWS ABOUT THE FUSE...LOL.
Sorry for making a new thread... thanks for helping out!!
Hello I have a 93 Honda del sol 1.5 and I'm having trouble with my check engine I already got the code with the paper clip and it came out to code#88 I was wondering if anyone has got this code before ?
adez1313
02-23-2013 04:57 PM
