civic ex with b16 swap high reving
i swapped in a b16 into my civic but the idle is high, 2000 rpm. why? i have no vacuum leaks on IM as i checked by spraying car cleaner...it has a constant idle at 2. when driving in gear, cruising i dont need to apply gas as it has enough to keep me moving.also new IM gasket and throttle body gasket looks good. any help
Re: civic ex with b16 swap high reving
try adjusting the tps as well if needed, if your cruising and u dont need to apply gas, it sounds like its stuck open a little bit. try checking throttle cable to for enough slack. jus lookin at everything for ya
DuecedSol
Honda Civic (2006 - 2015)
10
08-08-2014 07:26 PM
