Best 62mm Intake (B18C) on EG chassis?
Guys,
I know this question has probably been beaten to death, but I searched on the EG/Hybrid/Type-R Forums and was unable to find an answer.
ITR engine (62mm throttle body) in an EG chassis. Beside the whale ***** one, what other intakes (non CAI) would you guys recommend?
I bought a brand new intake from someone locally, but the opening of the intake is a bit smaller than the throttle body on my motor. I could adapt it, but I'd like to use something made for the ITR's 62mm TB.
What are your suggestions?
Thank you,
-Walter
Thank you,
-Walter
Re: Best 62mm Intake (B18C) on EG chassis?
AEM ITR 3" intake. (CAI Sytle). You will have an awesome looking powerband and the VTEC crossover is extremely loud. I will post a graph after I tune my ITR setup with that intake and several other bolt-on's.
Thanks for the replies guys.
Thanks for the advice, I looked up this picture and I think I see what you're suggesting.
Interesting. I looked both up and I found the Comptech Icebox you're referring to. I am a bit confused on the Mugen one, though. I see different solutions. Are you referring to the unit that looks very close to the factory airbox (with yellow conical filter) or the cylindrical glossy black unit? Do you have pics or part numbers I could use to narrow down the search? And where would you recommend to buy it? Being Mugen, I expect it to be very pricey.
Are you referring to the one 89t-rex mentioned?
Thanks again.
-Walter
Thanks again.
-Walter
hah. have fun with that money waste on mugen.
but a cheap ebay 3 in pipe short ram, a velocity stack and a decent filter(not the ebay one). that is the proven best intake. after that a tuned length will make it better.
-Walter
Generic 3" intake pipe w/ BPi stack and a K&N filter. Its proven itself time and time again on the 1.8's to make power over every intake on the market, with exception to the 3" AEM CAI. I have one for the track and untuned the top end is completely different over my whale ***** for DDing.
Information Leafblower
only problem is you buy the mugen your paying twice as much for a little emblem wit that japanese lettering under it.... get the aem v2 or just do a stock box with an em1 midpipe and a k&n filter.....
Well, the OP asked what the best intake was, not what the cheapest was. He didn't say money was an issue or else I would have recommended something else, like modifying the existing air box by removing the resonator, adding a K&N filter and an ITR rubber arm from the box to throttle body.
There's a lot of good intakes out there, but only a few that I would call the best.
i must admit you are correct he didnt state a price but i never let a fellow tuner waste money on something as silly as a "name brand" lol so many other options in the long run.... besides at the end of the day you compare all the real and fakes intakes... whats 2 hp on a stock c5???
Guys,
I really appreciate all of your input. I think I know which route I will be going (short ram + BPi stack and K&N filter).
Yes, I did not mention whether or not money was a determining factor. I guess it always is, but I was willing to spend the extra money if the product offered tangible advantages over cheaper solutions. It seems like the short-ram/stack/filter is a solid and proven solution that happens to cost under half of other ones like Mugen/WhalePenis etc, so I will try that first.
Thanks again for the input,
-Walter
-Walter
Yes, thats a good route. I also have a 3 inch short ram pipe (custom cut from generic bent tubing) with the Blox velocity stack+6 inch filter combo. This setup has the best proven gains. Tuned length helps though, I saw on the dyno that I get the most power and smoothest powerband when I lengthen the tubing more, and take off the filter. So when I go to the track, I put on an extra 2 inches of tubing I have (with couplers) and run a straight velocity stack with no filter (the filter wouldn't fit at this length anyway) and change it back because I think having a filter is safer for DDing.
Whats a BPi stack?
Whats a BPi stack?
Whats a BPi stack?
The BLOX unit seems way cheaper (even if it doesn't seem to have mounting accessories), but I wonder if it comes with a K&N filter like the BPi one. I'll email VelocityShop to inquire and report back, they usually reply very quickly.
-Walter
Damn, yeah that BPi thing is expensive but its cool that it comes with a K&N filter though, if theres even a difference. My Blox kit was only 50 or 60 bucks I think and it comes with a Blox filter. Looks exactly the same but I got a polished velocity stack instead of black.
I just realized that since the TB opening of a type r is 62 mm thats a little more than 2.5" so wouldn't a 2.5" short ram and 2.5" outlet velocity stack be better than 3" since I am effectively letting a half inch sit in side the couplers where air could possibly escape? But then you would HAVE to get the Blox stack cause BPi doesn't make a 2.5" inch one.
Thanks guys.
I wound up getting a 3" pipe mandrel bent for proper positioning under the hood.
I just got my K&N filter and Vibrant intake plug in the mail. BPi stack, Couplers and T-Bolt clamps are on the way.
Tomorrow I am going to a friend's shop to weld a bracket on the 3" pipe, then I am dropping it off to my other buddy to get it powdercoated flat black.
I'll open a new thread with pics of the whole process and the finished product.
-Walter
-Walter
Whats that Vibrant fitting for? You want to hook up a hose to the valve cover PCV system? Just putting a breather on the valve cover it better. Theres absolutely no need, performance wise, to put oil fumes back into your intake.
just keep it nice and simple
http://www.inlinefour.com/il4peprostin.html
-Walter
