If you had to choose between these transmissions???
It would be going into a 95 del sol S running a second gen b16a...Choices are...
1) rebuilt 0 mile usdm non-lsd b16a3 tranny
2) rebuilt 0 mile gsr non LSD hydro tranny
3) 10k mile rebuilt 97 spec JDM ITR LSD tranny w/4.7FD
I know what the obvious choice is...
What I would like to know is which is best for NA Which is best for FI...
Would just kinda like to know the way each act in each application I guess...
Thanks guys...
Thanks guys...
Re: If you had to choose between these transmissions???
Thanks guys...
Thanks guys...
sorry the final drive was changed at rebuild along with carbon syncros, recipet and pics a plenty...
Ok now what are there benifits/downfalls for na and FI
I love my itr tranny with lsd only reason why my b16 gets up so fast:} deff go with the itr short gears youll be glad you did
Well if you're going the whole NA path the B16 trans would be you're best route. Throw that LSD in and swap out 5th for a longer gear so you're not cruising at 70 turning 5500rpms lol
Ek Forever y0!
LSD > all
I wouldn't care if it were 25,000 or 50,000 miles or 75,000.
You can bet your *** honda did a better job assembling that ITR transmission than some mechanic did with either of those rebuilt transmission.
Did not even consider this..
Seagull Management
All 3 were rebuilt, just the ITR tranny's had 10k on it since rebuild. If a transmission is rebuilt properly, by a competent mechanic it should work every bit as well as a new tranny assembled by honda. Also, building honda manual trannys isn't exactly rocket science.
Ek Forever y0!
Thought I've heard of good results from OBX LSDs in the past too.
92TEGsrSC
01-05-2004 09:04 AM
