97 hx overheating
Re: 97 hx overheating
If the engine does not overheat with the heat on, this determines the water pump is physically moving coolant, no problem with flow on the "Motor" side of the cooling system.
This leaves only one cause, a blockage. Either the thermostat is failing to open, radiator is blocked or a hose collapsed. Most likely the first two.
Replace the thermostat, radiator cap, refill, and recheck.
I haven't replaced the thermostat, but i did have to change a hose the tore. I also replaced the radiator cap and flushed the radiator. Its still doing the same thing, I'll replace the thermostat and see if that's the problem. Thanks everyone for the help!
JamesTheMage
17
07-08-2013 07:18 AM
xpdude
03-31-2010 11:51 AM
ITLNstallion818
01-19-2005 11:31 AM
