99 civic hx turboed...just pulled dipstick and there is white pasty crap on it
ok, 99 civic hx turboed.... well i just pulled my dipstick and there is this white pasty crap on it... and it tries to overheat, but from what i seen most people with this same problem have no heat comin to the car, well i still do... once i turn the heat on it goes down to normal temp... i normally drive not even a mile a day... cause work is just right down the street... from my past experience if it was a blown head gasket, there would be no hope to get the temp back to operating temp.... im lost lol...
Re: something odd is goin on... need answers quick
most likely a blown headgasket remove your radiator cap and turn on the engine and see if you have bubbles blowing out of the radiator
Guessing his turbo is oil cooled since most are. Probably just a head gasket going bad slowly like has already been mentioned.
yes its oil cooled.... t3/t4 turbo... anyways... hahaha, u know what else dont work either.... no antifreeze in the radiator... god i feel so damn stupid... im prolly gonna get some here in a few then ill tell yal somethin...
Re: 99 civic hx turboed...just pulled dipstick and there is white pasty crap on it
Thread titles MUST be subject specific so that members browsing topics can easily understand the tech problem without reading the post:
https://honda-tech.com/forums/showpo...12&postcount=1
Please familiarize yourself with the stickies at the top.
Title edited.
The head gasket is almost certainly blown.
Title edited.
lol... idc at least i made someone laugh today lol... but i still havent went to go get some antifreeze.... i was tired as hell from work and just woke up... im bout to go get some now lol.... still makes me mad that happened... but, HOPEFULLY thats the only problem and its not the head gasket or somethin worse... im gonna put some in and try and check for cracks and leaks
Theres probably no antifreeze because you've been driving it so long with a blown head gasket...
And I would agree with two above that the coolant has leaked into the oil.
Just hope you head has not had this before, or they wont be able to shave it if it is out-of-round.
Usually when my car starts overheating (which it doesnt) I would check the radiator fluid after letting it cool down. We all prolly assumed that you did this by your first post; thus, it was striking to see that you had no coolant. MADE MY WEEK, not just my day! Best of luck chief. I have seen Honda's go through much worse.
Last week, some guy brought a new GSR he had got two days before. Guess the guy started cracking vtec all the time and never checked the oil. Owner had left oil low and the car was smoking a little, so it ended up with no oil. Blew a baby GSR with less than 100,000 miles in a bone stock GSR integra (not just a swapped GSR). I was like ohhhh myyyyyy goddd....really???
na everythin is back to normal... all the white crap is gone from the dipstick and from the oil cap and im runnin at normal temp again
Since that is solved ill share the worse overheating I have seen with my eyes:
Buddy with a fully built bored stroked b16 turbo pushing ~400 hp started overheating. The guy was trying to drive it back to his house by adding coolant and going. At one point it was overheating so bad and gushing coolant out that the car died. 15 minutes of cranking the engine did not work so he tried another 5 minutes. At the end of five the car started and he said, "Im not letting my foot off the gas til I get home." Went all the way back to his house boosting like a MotherF%^&*& and gushing stuff everywhere. The next day after the car was there, took the head off, took it to the machine shop and nothing was wrong with it!!!!! I said,"HOW?!?!?!?!?"
who the hell know lol.. well its still overheatin now but there is still no white crap on the dipstick or on the oil cap.... no water or white smoke from the exhaust... i smell no antifreeze... thermostat maybe???
H-T White Ops
An airlock can also cause bubbles out of the radiator cap. It doesn't mean anything is broken for sure. It could just mean it needs the air worked out and more coolant added.
ok... what bout pressure i heard if the hose really hard to squeeze then its a bad thermostat too...
new to this sight but been doin hondas for a while n sometimes...yes a bad thermostat can lead to high hose pressure...i.e not bein able to squeeze it but yea as the other guy said hoses are a safe bet to check for temp n pressure
Pressure would increase of course, just as if you turn the nozzle on a garden hose off, pressure increases in the hose. but I would not recommend grabbing your hot hose and and trying to feel for pressure, as you will burn you hand.
Just feel the hoses hot and cold and dont worry about the pressure...okay? The hot/cold test is usually fool-proof
