my 93 civic hatch with 95 b18b wont start....plz help
so i have been having problems with my car starting lately. i go to turn the car over and nothing happens, i try i again and agian, and nothing happens. then ill try again and presto it starts. so that was happening for a few day and now today it went to start, turned over a few time and just died i replaced the starter for nothing now and im getting more mad by the minute
car is a 93 civic hatch with a 95 b18b in it
ty
ty
Re: my car wont start....plz help
Check all your grounds, and clean them all. there are 3 of them, Clean the battery terminals and all that good stuff. Check all your fuses.
Does it roll over... but not start? or just nothing...?
now it does nothing and i cleaned all the grounds, checked fuses, replaced all the power and ground cables also
Re: my 93 civic hatch with 95 b18b wont start....plz help
If the fuel pump runs continuously when the key is held in ON(III)/START, then the ignition switch and starter switch on the clutch pedal is fine. It also predicts that the engine will push start. Check that.
Do you have a multimeter or test light?
Buy or borrow a multimeter because you need one to pinpoint the problem. Harbor Freight Tools has one for about $4.
Does the car push start?
ok push started it and let it run for like 2 min then shut it off and tried to start it......and presto it starts a million times better
well it started up like 10 more times and sounds a lot better when it starts
theEFsarecoming!
10
08-20-2014 09:58 AM
ekVtecPower
37
06-02-2006 10:01 PM
