Should I clean VTEC solenoid and coat the gasket with oil?
Old 08-25-2011, 09:18 AM
Ahhhlee's Avatar
Icon2 Should I clean VTEC solenoid and coat the gasket with oil?
Hello everyone,
car= 93 civic si h/b 1.6 d16z6
hoping to replace vtec selanoid/spool valve gaskets this weekend. For sure i have oil leak there. Car has 164k km's / 102k miles and i don't think its been done before. The honda service manual doesn't mention anything about putting fresh motor oil on the gaskets, but on other gaskets they do.
so just wanted to verify before proceeding. Do i have to coat the vtec selanoid gaskets with fresh motor oil? - or - do i just clean up the mating surfaces on the head and selanoid real good and then reinstall? Also do i have to clean the inside of the vtec selanoid with brake cleaner or just leave it be?
look forward to your insights,
thanks
Old 08-25-2011, 05:10 PM
Ahhhlee's Avatar
Default Re: Should I clean VTEC solenoid and coat the gasket with oil?
bump
Old 08-25-2011, 07:19 PM
CivicBlacksheep's Avatar
U can clean the head with brake cleaner, ive done it before, have had no problems with it...i also advise u coating the gasket with a little oil...makes 4 an easier install and swells gasket slightly...good luck
Old 08-26-2011, 05:35 AM
Ahhhlee's Avatar
Appreciate your reply CivicBlacksheep.
Alright then its confirmed; Apply a little bit of fresh motor oil on vtec solenoid gaskets (the one on top of the solenoid & the one on the side against cylinder head).
SaltyDog017
27
02-24-2012 02:56 PM
NiK
07-10-2007 04:33 AM
trooper0641
09-09-2004 04:57 PM
JICsube
10-30-2002 11:36 PM
Quick Reply: Should I clean VTEC solenoid and coat the gasket with oil?
