EJ stalled and now won't start
Sup people, new to the site and my first post is a fuel issue.
I was at a stop sign and put it in 1st and the throttle started bogging out, I figured I just ran empty cause I was pretty low and on my way to the gas station. but got fuel in my car went to start it and it started but the idle was crazy and when I pressed the gas it stalled out, and after it never wanted to turn over. I`m sort of stuck I dont know if its the main relay which for some reason isnt in the right spot in my ej and cant seem to find it or if its the fuel pump or tps.
anyone have any ideas?
Re: fuel problems
If its not turning over its not gonna be your main relay or the fuel pump neither of them have anything to do with turning over. Is the fuel pump priming before you start the car? Should be a buzzing or humming noise when you put the key on II.
Re: EJ stalled and now won't start
What type of problem is this?
--> No-crank (starter doesn't turn engine)
or
--> Crank-but-no-start (starter turns the engine but it won't start)
or
Jooleeus
13
07-20-2008 08:46 AM
