93 cx d15b2 swap now stock tranny won't work
I would appreciate any insight into my problem. After many headaches I got the d15b2 motor in and running. I left the stock tranny in which worked fine in the d15b8, but it just won't pull now. I've taken the tranny out 3 times now. replaced the throwout bearing. The hydraulic piston engages the clutch fork fine. I can hear the gears changing with the shifter, but when i let off the clutch while in gear the car won't stall. Absolutely no power reaches the wheels. I switched my ecu from a p05 to a p06 and back. I swapped pressure plates, the clutch looks great and still.....nothing. Please give me some more ideas if you have them.
Re: 93 cx d15b2 swap now stock tranny won't work
i checked my axles and the passenger side was out an inch. i used a 2x4, towel and a rubber mallet to finally get it in. Drove my car around the neighborhood for the first time in 3 weeks. thank you so much.
ek4si
Transmission & Drivetrain
06-13-2012 06:45 AM
