Can a power moon roof switch be repaired?
96 civic ex.
Can you repair a moonroof switch? Can it be opened?
It pops open up, hard time going back like the button is bottomed out, so going back will work once and awhile.
H-T White Ops
Re: Can a power moon roof switch be repaired?
I've never attempted to repair a switch since it's usually just so cheap to replace. $5-10 should get you another used one. They don't commonly break.
H-T White Ops
I see one on eBay right now for $15!
Seriously, where did you get that quote of $65 for a USED switch, like I mentioned?
If you go to a local junkyard you'll likely find them for cheaper, or check the classifieds on this site or others.
Any '96-'00 Civic EX (coupe/sedan) or Si will have the switch. If you need the light gray switch you'll need to get it from an EX (coupe or sedan) and if you need a tan switch you'll need to get it from an EX (sedan). The dark gray ones come in the EX (coupe) and Si.
The Grumpiest
Where are you finding a USED moonroof switch for $65? They're listed as $55 new from Honda even!
H-T White Ops
So why don't you buy a used one as I suggested? Switches don't often break. Yours is broken and will require effort that stands a high chance of failure due to lack of experience and parts.
all that holds the switch button on is two plastic nipples all u need to do is pry the sides a little so it clears the nipple and it will come off easily. then once off youll see what i mean. if ur metal contacts are in real bad shape this will be a temp fix. i heated mine up and dumped them in water like a black smith would.. i dont recomend that as i dont actually know if it helped but im still on the first switch so something worked. defitnatly rebending it fixes it but with any metal if u keep bending it it weakens every time.
H-T White Ops
I had a foglight switch we disassembled because it sometimes wouldn't stay on. Iirc there was broken plastic in it when we took it apart. I suppose epoxy might have been able to repaired it but I just got another one for $5.
SR20 Inside
01-25-2006 09:24 PM
