Oil dripping from D16z6 tranny
Re: D16z6 Vtec
yes, it mean tranny. my badly. it was between the tranny and engine. i just looking it. i am not sure why it is oil droping. is that true if i have to get tranny out and put new gasket put on between engine and tranny?? let me know. thank you for your help
Re: D16z6 Vtec
between the tranny and motor is a cheap 8 dollar rear main seal gasket but it takes hrs to replace it. it's behind the flywheel and the transmission needs removed... goodluck. if you don't replace it it will go through quarts of oil a day.
Risky Business
Re: D16z6 Vtec
One of two seals. Rear main seal (on block, means engine is leaking oil), or input shaft seal (in transmission, means transmission is leaking fluid).
Transmission will have to be dropped to replace either.
Re: Oil dripping from D16z6 tranny
First figure out whether the oil is leaking from the transmission or engine. Look for a possible source higher up on the engine (VTEC, distributor, valve cover, oil pan) or from the axle seals.
^That, particularly the distributor o-ring, valve cover gasket and VTEC solenoid. The oil will run all the way down to the bottom.
Otherwise probably the rear main seal, but check the easier seals first.
Clean your engine with degreaser so you can pinpoint where the oil is coming from.
petty$rep
18
10-12-2006 07:53 AM
