eg LS swap help
eg LS swap help
hey honda tech need a little help. Im new to the honda scene since im more of a muscle car builder but decided to see if i can have fun with a honda. ok so i bought a 93 eg bubble shell that i want to put an ls motor in. my friend just totaled his 97 integra and he was gunna give me the things i need to do the swap but the problem i think id be facing is that the integra is an obd2 and the bubble is obd1 so would i still be able to use the motor and trans and just get a different harness? just need a list of the **** ill need and what other parts would be able to swap over likes brakes, interior? thanks for the help
Technical Hero
Re: eg LS swap help
If you get his engine wiring harness that connects to the shock tower on the passenger side it'll be plug and play. You don't need the OBD1 distributor, alternator and injectors. You will want to get an OBD1 92-95 LS P74/75 ECU however. You don't want to use an OBD2 ECU.
TURBOED-TEG
09-17-2002 05:05 AM
