car idle, jumping, and clock dimming
today i changed the oil and filter on the car.
i drove it a couple blocks and it came back home, it was fine...
then, drove it out tonight... a couple hours after before and the car was running
rough, like it didn't want to go, then it was idling weird sometimes when the car was stopped and i noticed the clock would get dim on and off even if the car wasn't idling weird.
i know one battery terminal is corroded, would it cause that?
or would it be a fuse problem? thanks.
Re: car idle, jumping, and clock dimming
if your terminal is corroded then you have a bad connection, which will cause your Honda to run like **** and not even start at times.
easy test... get a DVOM put the black wire to - and red to + and start the car... If your below 14.xx then your alt is prob on its way out. You can also check if the grounds are dirty by Making a test lead... hook it to your - battery cable and while the car is running touch diffrent areas around grounding points if the volage rises then you have a bad ground or more then one. Make sure to use 12awg wire as it can flow more current..
antig24
06-27-2009 10:27 AM
