y does it take a long time for o/d to kick in?
i noticed here lately when im on the highway that my o/d takes a long time to kick in. Is it because its cold and the fluid in thick and needs to warm up or is there a solinod goin bad? any help will be nice. need to know if i need to look at anything or replace something. thanks james
Re: y does it take a long time for o/d to kick in?
When is the last time the fluid was changed? Usually it kicks in at speeds above 50mph when you let off the gas. So if your accelerating moderatly up to 60 or 70 then let off it will kick into OD.
fluid was changed 4 months ago, and if i go 65 takes like 3 miles of driven thats when i leave my house. wont do it when it after driven all day. sometimes it will pop out of o/d too for a sec or 2 out of the blue. if that will help
there is no filter to this trans to change. if its kicking out of over drive thats not a good sign unless ur more then past half throttle. drain some fluid and add alil bit of no slip lucus. it actually does work pretty well in the d series trans ive used it in mine before it went bad and got alot of extra miles out of it that i know i wouldn't have got without it. see if thickening the fluid up with that helps at all. it will take 500 miles or so for it to fully mix in. id only add half a bottle and try that.
ok thanks ill try that. when it does pop out im just goin the speed limit only once in a blue moon it will do it.
dk199160
10-23-2015 11:54 AM
theLemur
12-27-2014 01:01 PM
integracura
05-29-2006 04:32 PM
